Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-12-2007, 05:26 PM
CuriousInventor is on a distinguished road
Material / Hardness / Plating for Tapping Block
Hi, I'm going to make a tapping block (chunk of metal with holes to help align hand taps), and I thought I'd try and learn a bit about material selection, hardness, and plating at the same time.
The goal is to make something that can get thrown around in the shop a bit without getting dinged up and also won't rust.
Right now I'm planning on making it from 4140, heat treating to RC30 or 40, and applying electroless nickel plating. Is this overkill?
Old 09-12-2007, 10:57 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Overkill? Yes. I say overkill, because I find myself drilling new guide holes in the block all the time. I choose to only drill the holes I need at the time I needed them. I think it makes the block easier to use than just a generic block full of holes.
You can make an effective tapping block from aluminum, as long as the smooth part of the tap can ride on the wall of the hole. I've tapped thousands of holes using my simple aluminum block, to speck. Dont get me wrong, hardened steel would definately be a better solution, but for the effort involved, it's not worth it in my mind. Plating? As long as you don't plate the insides of the holes. There would be alot of plugging involved.
Just my 2 cents.
Paul
Old 09-13-2007, 12:20 AM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
Damn I think at tapping block at all is over kill, a 1-2-3 block to check if its going in straight is very easy and effective.
Live free or die
Old 09-13-2007, 12:50 AM
In the good old days you just lined it up by eye .
In the good new days I put it in the CNC and write a two line MDI program.
Tapping in hardened Material machinist77 General Metalwork Discussion 16 04-25-2007 04:09 PM
Rockwell hardness testers mtechserv General Metalwork Discussion 2 03-19-2006 06:03 PM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 01:52 AM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 09:10 PM
Taking the hardness out of steel DJ Morrow General Metal Working Machines 13 01-29-2004 05:18 PM
