| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Hello....I am making a vibrating table to polish marble. Would appreciate input on the mechanism to make it vibrate. So far.....steel pan....4' x 2' mounted on 4 heavy duty rubber isolation mounts. Idea 1....4 foot long HORIZOTAL shaft in 4 pillow blocks...and 2 cam lobes running along the side of the pan....pushing it sideways. Idea 2 VERTICAL shaft underneath with a cam lobe on the end....spinning around and hitting a metal bar, welded to the bottom of the pan...pushing it sideways Idea 3 Vertical shaft underneath with a cam lob spinning around inside a ring....welded to the bottom of the pan....pushing out in 360 degrees.... Idea 4 should I do something with an eccentric? if so what? Would appreciate any input... Thanks, Leland |
| Hi Leland, I've done this on a smaller scale. I needed a cheap, but larger than normal vibratory bowl for polishing jewelry parts. I used a 18" pan for changing your car oil and an $11.99 walmart fan motor. The motor was mounted in a wooden ring with 4 springs around it. Different thicknesses and lengths of springs were tried. the bowl was attached to the top of the springs on a second wood ring... cut out with a simple circle cutting router attachment. I just bolted a piece of brass to the motor shaft to make it wobble like an SOB....A few experiments with the springs(they're pretty heavy duty...from ACE hardware) and it worked like an industrial charm. I still have it. I ran it for DAYS at a time for about 12 years. I was always prepared to upgrade the motor to a regular 1/2 horse or so, because I was so reliant on the thing. But it just kept working. I'll have to get you some pictures. It's a sorry looking thing, but it's unstoppable. That on an adjusted scale would work great. I wanted to do the same thing you're talking about to polish flat surfaces, but I just haven't gotten to it yet. CNC got in the way ![]() John |
| Check this one out, a simple but very nice solution: http://www.cnczone.com/forums/showpo...postcount=2079 Regards, Sven |
| I built a 48" x 96" vibrating table for casting concrete 10 years ago and still use it. Check out Vibco for electric or pnuematic vibrators, and you'll definitely want to use air bags to isolate the table from the base, unless you want the whole house shaking loose. I got mine from Goodyear. If you want more details let me know. Burt |
| There is this faint vibrating/hissing/humming feels to my stepper motor. Why? | alexccmeister | Automation Technology Products | 9 | 05-20-2007 08:45 PM |
| XY table design basics, linear ways to table size ratio? | Konstantin | Mechanical Calculations/Engineering Design | 0 | 03-13-2007 01:21 PM |
| Looking for input on CNC table design | yellow73bb | CNC Plasma and Waterjet Machines | 2 | 10-16-2006 12:20 PM |
| new table design question | KTP | DIY-CNC Router Table Machines | 5 | 07-21-2006 05:21 PM |
| My plasma table design | m_c | CNC Plasma and Waterjet Machines | 16 | 07-24-2004 02:01 PM |
