Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-08-2007, 08:29 AM
confusion is on a distinguished road
harmonic drive helps
Hi!
i was given a project to model a harmonic drive system driven by dc servo but nw i dunno where im suppose to begin... i had did my homework by studying the working principle, availability of diff types...but its very difficult to get knw the whole things just by reading...my problem is i need to buy all my stuffs frm oversea which means i must knw correctly wat i want to buy b4 placing orders...
i dunno how actualy we attach the servo to HD...and can any servo be attached to any harmonic gear?
any suggestion for which gear i should buy?(my project is not for any application, just do research for general purpose drive)
im not asking any1 to do my project for me, its just that i hope that sm1 can provide me guidance.
Regards,
Confusion
Old 09-09-2007, 07:17 PM
walter's Avatar
Gold Member
walter is on a distinguished road
Start here:
Harmonic Drive
5 axis question
Old 09-10-2007, 01:04 PM
cueshark is on a distinguished road
Smile
walter, did you ever build the housing you mentioned in thethread you linked too? thanks greg
Old 09-10-2007, 05:29 PM
walter's Avatar
Gold Member
No. I found the entire assembly on ebay and that part went into the dustbin.
Home Made 4th Axis with Harmonic Drive Unit! widgitmaster Benchtop Machines 30 06-06-2007 12:14 AM
harmonic drive, max RPM stepper or servo Art Ransom Mechanical Calculations/Engineering Design 5 12-11-2006 11:26 PM
Harmonic Drive juzwuz Mechanical Calculations/Engineering Design 13 12-03-2005 02:28 AM
Harmonic drive - keeping position? medved Mechanical Calculations/Engineering Design 1 11-30-2005 07:49 PM
Mill Expert Helps Build the Ford GT OneCNC OneCNC 1 11-06-2003 08:17 PM
