Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 08-08-2007, 02:49 PM
krismcneil is on a distinguished road
Thread Measuring
Guys, whats the formula to find the thread of say a grinding wheel spindle ( 10" dia) i need to make a new flange to mount on it to accompany a balancing head on the wheel. I need to find what type of thread is on the spindle to make the new nut.
thanks,
Old 08-21-2007, 06:19 PM
jrrdw's Avatar
jrrdw is on a distinguished road
Don't you have thread pitch gauges? You can find the at your local hardware store, and they come standered with tap and die sets.
Make sure you clean my wrench before you put it back into my toolbox.
Old 08-21-2007, 08:47 PM
krismcneil, Your profile says "man. eng.". Is that the same as Manufacturing Engineer (Mfg. Eng.)? If so, you are going to need "the source", Machinery's Handbook, which contains thread formulea, thread measuring methods and most everything else you will eventually need concerning machining. If you don't have a copy, I'd strongly suggest getting one.
DZASTR
Measuring FTT and OEE in CNC Shop WayneHill General Metalwork Discussion 2 06-30-2011 11:09 AM
Asimeto measuring tools? Chuck Reamer Calibration & Measurement 3 02-15-2008 09:26 AM
Measuring following error eldata Mach Mill 0 02-23-2007 09:54 AM
Measuring Gears Flyinfool General Metalwork Discussion 5 05-24-2006 04:02 PM
Measuring question? pstockley General Metalwork Discussion 3 02-03-2006 07:14 PM
