Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 07-19-2007, 11:38 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Bearing recommendation for this app?
I would like to hear some thoughts on the type of bearings to use in the swivel joints in this machine:
http://video.google.com/videoplay?do...54094403949989
This will be around a lot of water, sand and dirt.
Dennis
Dennis
Old 07-20-2007, 02:44 AM
Zumba is on a distinguished road
Probably just a simple deep groove radial with rubber seals. 62XX-2RS or 63XX-2RS. You'll have to do some math to see if they can handle the loads. Use 6300 series bearings and/or multiple bearings if need higher capacity.
Cam Recommendation dgoddard General CAM Discussion 0 06-15-2007 09:38 AM
CAD/CAM recommendation split63 General CAM Discussion 9 06-11-2007 06:59 PM
Recommendation Please SPEEDRE Autodesk Software (Autocad, Inventor etc) 0 02-12-2007 06:33 PM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 03:49 PM
lathe recommendation marty7001 General Metal Working Machines 0 04-28-2006 12:43 AM
