Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 07-12-2007, 04:07 PM
BrendaEM is on a distinguished road
Cutting a Surface plate?
I could use 36" or 48" surface plate, but no one makes one that's 8" or 12" wide. A wide plate of that length would be too heavy for my uses, such as guitar fretboard truing.
Can a surface plate be cut the long way without destroying its accuracy? Are there internal stresses that would just ruin the accuracy?
I had thought it could be cut by a water-cooled diamond blade in gravestone or counter top shop.
I was also thinking that splitting a 24" plate into three would yield 3 plates that could, hypothetically be trued together, if need be. The pieces would still be over a hundred pounds but could slide on find grinding compound or cerium oxide, such as the telescope people use.
Old 07-12-2007, 04:15 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I wouldn't imagine that cutting a block of granite would ruin it's flatness.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 07-12-2007, 07:56 PM
USMCPOP is on a distinguished road
Find a place that does granite counter tops. Go around back, and get a few scraps from their dumpster. Get a roughly matching pair, and play around with lapping them a little bit if they need it. How flat do you really need it?
Old 07-12-2007, 08:05 PM
Flatness, for instance a guitar fret will buzz if it's .002 off. I would like to make other straightedges from the surface plate too.
Both require only a small portion of a large surface plate. I've seen granite straightedges before, which would be ideal, but I could probably have a surface plate cut for less.
I'm surprised that long aspect ration plates aren't common.
Old 07-15-2007, 09:30 PM
lgalla's Avatar
lgalla is on a distinguished road
Checkout this E-bay store.
http://stores.ebay.com/Discount-Machine-Shop
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 07-16-2007, 02:41 AM
bigbunny5's Avatar
bigbunny5 is on a distinguished road
If it were me I'd go out and get the ElCheepo Grizly surface plate and find some one with a Water Jet cutter. I know the one at the shop I use to cut stuff can cut up to 5" think Marble.
An idea that is not dangerous is unworthy of being called an idea at all, and Consistency is the last refuge of the unimaginative.
Old 07-17-2007, 12:36 PM
How about a nearby memorial marker (gravestone) shop? I'd think they could cut a piece of granite or marble the size you want and probably grind it as flat as you require. I bet you could have it surface ground at a grind shop if the memorial shop couldn't.
Just a thought.
DZASTR
Old 07-22-2007, 02:47 PM
project5k's Avatar
project5k is on a distinguished road
if you did that, could you then say it was "dead flat"?
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 07-22-2007, 04:05 PM
I believe you're "dead right".
DZASTR
Old 07-22-2007, 05:44 PM
project5k's Avatar
good, i was afraid i was "gravely" mistaken..
Old 07-23-2007, 02:50 PM
mxtras's Avatar
Silver Member
I'll bet it would be deadly accurate!
Scott
  #12   Ban this user!
Old 07-23-2007, 05:43 PM
I suspect these comments will be terminated. That is, of course, unless they are resurected by someone who believes in reincarnation.
DZASTR
Cutting thick steel plate Woodenspoke General Metalwork Discussion 25 07-12-2007 12:58 AM
Engineer's Surface Plate - float glass? andy_ck87028 Mechanical Calculations/Engineering Design 17 06-17-2007 11:16 AM
cutting long cut in 1/2 steel plate ZipSnipe General Metalwork Discussion 7 06-09-2006 07:47 AM
Cleaning Granite Surface Plate? MrRage General Metal Working Machines 4 02-01-2006 01:09 AM
Cutting 3/8 steel plate BlueC General Metalwork Discussion 2 05-21-2004 11:06 PM
