Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-27-2007, 06:03 PM
metalcraft.hr is on a distinguished road
Articulated Arm - how to make
I need to meke articulated arm for hanging painting compressor 3 cables during the painting. Have someone idea how to make articulated arm simple?
Old 06-29-2007, 04:58 PM
USMCPOP is on a distinguished road
Heck, yes. Use a wrecked bicycle. Discard the handlebars. Bend the forks out, or cut the forks short and weld on some square tubing for the outer arm. Cut off the frame where it meets the seat tube, and weld that onto a floor pole. Or shove the seat tube onto another tube that mounts to the floor so you can swivel that. Or combine the parts of two bicycles. Bearings and races are readily available, and relatively inexpensive. Done.
Old 06-29-2007, 05:01 PM
Originally Posted by USMCPOP View Post
Heck, yes. Get hold of a scrapped bicycle. Chuck the handlebars. Bend the forks out, or cut the forks short and weld on some square tubing for the outer arm. Cut off the frame where it meets the seat tube, and weld that onto a floor pole. Or shove the seat tube onto another tube that mounts to the floor so you can swivel that. Or combine the parts of two bicycles. Bearings and races are readily available, and cheap. Done.
Excellent idea, great. I newr think on plane simple bicycle. Am I asking too mouch if You can give me some drawing idea. I see thet You have great thinking on this... I am blocked.
Old 06-29-2007, 05:28 PM
Door hinges or gate hinges would work very nicely as well. They could be bolted to wooden arms and you would not need to weld. Think simple.
Old 06-29-2007, 05:30 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Box tubing, a few bolts and nuts, a few nylon washers and a drill.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-29-2007, 06:43 PM
Scott,
Maybe you could use those parts to make that AL tubing polisher machine, LOL. Any progress?
You're right, any kind of homemade hinge would do it. It's just that I always wanted to make something out of old bicycles. They deserve a better fate than the scrapyard.
Old 06-30-2007, 04:25 AM
Scott,
What exactly I douing. I have building new trolley like this on pictures, on which is two tanks and it will be small welding machine. I trying to make articulated arm attchement for cables to prevent to cables drag on floor during some specific welding.
ID:	39885   Click image for larger version
ID:	39886   Click image for larger version
Anyone know how to make this? ImanCarrot General Metalwork Discussion 4 06-20-2007 11:37 AM
How would you make this? Art Ransom Wood Lathes / Mills 5 01-09-2007 07:03 AM
trying to make a die. Dougotio Diemaking and Diecutting 9 04-08-2006 06:37 PM
CNC able to make this? kentrob11 Hobby Discussion 92 03-09-2006 09:30 AM
How can I make cncman General Electronics Discussion 3 03-23-2004 02:49 PM
