Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-25-2007, 10:35 PM
luther is on a distinguished road
Question homemade linear bearings for a 48"x96" router
hi, new to cnc ground up fab. i was wornding if i mounted a piece of 1" cold roll steel on top and on bottom of a 3" c-channel shoud be strong enough for a 48" x96" router/plasma table for x,y axis i plan on useing 608zz skateboard bearing 6 on top and 6 on bottom . and what size of steppers do i need ? i find some at hobbycnc.com the size is 305oz-in unipolar rating, 6v, 2A, 200 S/R is that enough for router and plasma table
Will this work for linear bearings? luther Linear and Rotary Motion 0 06-23-2007 11:09 PM
linear bearings studysession DIY-CNC Router Table Machines 1 01-16-2007 05:21 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 11:06 AM
linear bearings broncosis DIY-CNC Router Table Machines 0 06-10-2004 07:03 PM
Need help on linear bearings bbergami DIY-CNC Router Table Machines 11 05-25-2004 07:04 PM
