Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-25-2007, 03:33 PM
Blinky_Boy is on a distinguished road
Question Nylon molding at home (for inventions)
Anyone used/a nylon molding device? Such as an injection mold? im looking for a cheap injection mold. but instead of using aluminum blocks as the negitives, could you use a ceramic type? it would be alot easir to shape, but i dont know how well it would work.
thanks for viewing, im new to this site and composites.
The Big S
Old 06-29-2007, 09:09 AM
ewest is on a distinguished road
a couple things on injection molding and nylon.. I don't want to burst your bubble, but do some homework first. I can tell you this.
You can't take a bunch of rope and chop it up and put it in a sauce pan, melt it on the stove, and pour it in a mold like lead or pewter.
- Aluminum is considered to be the cheap mold material, and ceramic is a LOT HARDER to machine. Plus, with molding, a conductive mold material is good, because you can better control the temperature of the mold.
Next up, nylon is a super mega royal bit¢h to mold. OK there are probably things that are worse, but nylon has to be dried for HOURS before molding - down to 0.1% moisture or less, heated to 450ºF-500ºF, and injected at pressures around 10,000 PSI..... and it loves to scorch and burn, and smells horrible when it does....
NOW, they do have bench top molding machines. I'm not sure what the price is - I know they're not hundreds of dollars, but they CAN do nylon. Here's one...
http://www.mini-jector.com/model45.html
or a
http://www.rondolusa.com/im/hf5/
If you want to mold plastics, I'd look in to casting urethanes. You'll get good results, and if you've got the kind of budget that is conscious about the cost of a block of aluminum, I really think that you might have trouble justifying the cost of the equipment needed to injection mold thermoplastics to even the lowest level of quality. Then again, some people have reportedly made injection molds out of epoxy (not Devcon 5 minute, mind you)
The good news is, however, that this IS a forum with a bunch of machinists in it... I'm sure somebody could help you get the parts you need!
Old 06-29-2007, 04:32 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Blinky Boy -
welcome to the zone! You didn't say - I suspect don't want to share the invention specifics, but if you just need low volume production of models or prototypes for testing - have you considered plastic casting? You kinda have to watch for shrinkage - but you can get high quality parts for fitment checks, demonstrations etc.
As an alternative maybe just mill the piece one at a time. Then, when ready to license for production, you'll sit back and watch the money come rolling in!
HA- don't I wish
For my bits I'm doing some of each, milling and plastic/resin casting. I priced having zinc molds built in OZ and they would be A$2000, for my molds. Decided on other path.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Machining/Cutting Nylon? barkster Benchtop Machines 31 01-18-2011 10:21 PM
Advise on what taps to use for nylon msomerville General Material Machining Solutions 5 01-16-2007 03:45 PM
Molding plastics at home? Bartman Glass, Plastic and Stone 3 10-06-2006 02:32 PM
6/6 Nylon dighsx DIY-CNC Router Table Machines 0 04-28-2006 07:49 AM
window channel and nylon ShayArnett DIY-CNC Router Table Machines 3 12-25-2004 11:36 PM
