Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-03-2007, 11:01 PM
jimtom is on a distinguished road
force applied to table ? is there an easy way to calculate it ?
Does anyone know if there is an easy way to calculate the force that gets applied from a certain motor torque and screw combination, example 200oz.in. motor + 1/2-10 lead screw what would be the final force to the sliding table, I relized that there are some other factors like fiction on the screw and slide, but is there some sort of online calculator or easy equation to use to check multiple combinations?
Thanks Jim
Old 06-04-2007, 07:16 PM
martinw is on a distinguished road
Thanks Jim
Dear Jim,
Try this....http://www.smallmotors.com/html/lead_screws.html
Best wishes
Martin
Old 06-05-2007, 12:10 AM
Thanks Martin
Great information, very helpful
Old 06-05-2007, 10:36 PM
Thanks Martin
Dear Jim,
I think you should be aware that I may have "passed you a bummer".
The L in the equation is the linear advance of the screw per revolution, not the "small l" in the diagram, the length of the screw.
You may have spotted it, but I feel guilty for possibly confusing you.
I do apologise.
Best wishes
Martin
How do I calculate my gear ratios? Apples Linear and Rotary Motion 2 09-17-2006 07:39 AM
Have you ever applied for patent rights? widgitmaster CNCzone Club House 11 08-11-2006 01:04 PM
Cam- gear motor - force applied to follower? Chris D Mechanical Calculations/Engineering Design 3 05-05-2006 12:41 PM
how to calculate flex dertsap Mechanical Calculations/Engineering Design 14 04-17-2006 07:22 PM
How do I calculate this? CNCadmin Mechanical Calculations/Engineering Design 2 02-05-2005 10:24 AM
