| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Is there a table or calculations for figuring out how much weight a column can tolerate? Lets say 4' piece of 2" square tube 1/8" wall thickness, how much weight can be applied before it starts to deflect? |
| Look up Euler's Formula. Basically the critical buckling load (beyond elastic limit) for a vertical column is; Fcr=(ExIxPi^2)/L^2 Where; Fcr=critical force or load, E=youngs modulus for material, I = area moment of inertia of the horizontal cross section L= column length note that critical load decreases with the square of the column length L used in the formula changes depending on how the ends of the column are terminated. There's a table somewhere but if the ends are clamped solid then L = 0.5 x actual length. If they're free to float it's 2.0 x actual length and various permutations in between. |
| loading ballscrew nut | russell | DIY-CNC Router Table Machines | 18 | 08-03-2011 02:48 PM |
| Loading Limit | martindugdale | CNC Machining Centers | 0 | 05-08-2007 08:06 AM |
| loading programs into dos | bkstout | General CNC (Mill and Lathe) Control Software (NC) | 7 | 02-12-2006 09:05 PM |
| re-loading ballscrews | marx911 | General Metal Working Machines | 17 | 09-04-2005 01:19 AM |
| Down/up loading offsets | JPann | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 03-21-2004 09:17 PM |
