| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Simple question ....how? My guess is to use an angle grinder with a thin cutoff disc Should I cool it as I cut it? Should I cut it over a ten minute period with a 2 minute cool down between each 5 second cut? Do I file it after with a hand file or angle grinder with a grinding disc? Do I hold it in my hand or put it in the vice with soft jaws? Does it matter? Andy NB I know I mustn't drop it!!
__________________ Drat, imperfection has finally stopped working!! |
| yes that will work KEEP IT COOL!!!, it might not be hardened all the way through so pour some water on it, let it draw the heat away and cut again yes go slow and take many small cuts a file probabaly wont touch it, use a bench grinder or an angle grinder OMG dont hold it in your hand!!!!! us a vice or clamp it to a desk yes it matters! yeah dont drop it! |
| Hello, I cut hardened steel shafts with a 300mm grind cutter. The disk is 3 mm thick. I cut a 16 mm in about 30 seconds without cooling. After cutting, I quench its end it in water. As you can see in the picture the heat affected zone is about 3 millimeters, quite negligible, since this section will be held in the supports and has no contact with the bearing. Cutting 25 mm shafts also had the same result. Nader |
I often have to cut stainless nuts from stainless bolts on the job. I use a very thin abrassive cutoff disk chucked in a cordless drill. Held very firmly I can slice through a nut and 3/8 bolt fairly quickly. I have applied the same scheme to cutting hardend rod using my drill press. I chuck the cutoff disk in the drill press, run it at medium speed, put the rod in the cross slide vice, and slooooooowly feed the piece through the spinning disk. Often is still cool enough to handle after cutting, and a nice smooth cut. Steve |
| Spot drilling case hardened steel | Zumba | General Metalwork Discussion | 20 | 03-04-2007 02:32 PM |
| Machining Hardened Steel Shaft | jimbobbus3 | General Metalwork Discussion | 15 | 11-09-2006 10:41 PM |
| hardened shaft vs unsupported length | project5k | DIY-CNC Router Table Machines | 24 | 09-25-2006 08:27 PM |
| Cutting Hardened Steel | Smackre | CNC Plasma and Waterjet Machines | 0 | 02-08-2006 02:12 PM |
| Drilling hardened steel shaft | Zephrant | General Metal Working Machines | 12 | 06-13-2003 04:42 PM |
