Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-20-2007, 08:38 PM
Leesbrass is on a distinguished road
Newbie here in desperate need of tech support!
Hello folks. this is my first post.
Goal: Find a fairly small metal lathe and related hardware/software to produce, design and customize trumpet mouthpieces. That and some helpful guides, literature etc.
Don't need much size as a mouthpiece is less than four inches long. I have plenty of brass rod stock.
Thank you for your anticipated support in advance.
Lee
Old 05-20-2007, 09:05 PM
gmfoster is on a distinguished road
here is a good place to start..look around the site a lot...
http://www.dakeng.com
Good Luck
garry
Old 05-20-2007, 09:07 PM
JRoque is on a distinguished road
Hello and welcome.
One choice is member JFettig's (Jon) products: http://jfettigmachines.com/ I believe he offers a complete small lathe converted to CNC. For software, you can run Mach which is great and inexpensive. Jon can give you all the details.
JR
Bridgeport Tech support sharp-shooter Bridgeport and Hardinge Mills 2 01-04-2007 05:10 PM
Desperate times call for desperate measures lilricky2 Mastercam 17 06-14-2006 09:48 AM
To Tech Support Billyboy CamSoft Products 7 01-30-2006 05:24 PM
Newbie leadscrew support/bearing question lukaslouw DIY-CNC Router Table Machines 0 09-23-2005 11:03 AM
In Desperate Need Al_The_Man Servo Motors and Drives 0 08-02-2005 01:55 PM
