Hi, lots of very accurate motion control stages use timing belts and pulleys driven by servo and stepper motors and accuracy is not lost when the motors reverse. However you will need to design in a tension adjust and like anything, the more parts you have the more attention and maintenance it will need. If you can couple directly with something like a helical or bellows style coupling that will simplify the mechanics but if you need pulleys for torque multiplication or for motor placement belts and pulleys are fine.
LinkBack URL
About LinkBacks
