Results 1 to 7 of 7
Thread: Free Granite for Machine Bases
    Mar 2007
    Red face Free Granite for Machine Bases
    When they make granite countertops they saw the roughly 6x10 foot slabs of 1-1/4 inch granite into pieces on a big saw with an overarm and a table. They get chunks they can't do anything useful with. The yard I visit is littered with them.
    I bought a cheap tile saw and it churns through this granite amazingly well.
    If you don't care what *color* your machine is, or that it is made from different color pieces, you could homebuild all kinds of stable structures from these chucks and a cheap saw. When it's all done, you could paint it, I suppose, but that would ruin the beauty of the stone.
    Doug Goncz
    Replikon Research
    Seven Corners, VA 22044-0394
    Gold Member walter's Avatar
    May 2003
    Good info. Thanks.
    Registered vger's Avatar
    Jan 2006
    cutting granite slabs
    Good post. The saw in the granite shop they use is called a "Bridge Saw". I have seen people make these same long cuts with an angle grinder using diamond blades and doing it dry! A little tough on blades and not quite as accurate but it works (wear face sheild and dust mask). The granite you were talking about is probably the 3 cm slabs. There are also 2 cm slabs that are used. To make the edge thicker on the 2 cm material they cut a narrow strip and epoxy it to the underside of the edge and get a 4 cm thick edge. I suppose one could do long 45 deg miter cuts and build box frames with epoxy. Stiff but lighter.
    Seams on counter tops are epoxied together, sometimes with epoxy fiberglass backup underneath.
    Dec 2006
    Post A Picture
    I would like to see a picture of a cnc machine built from this, will you please post a picture?
    Dan
    Apr 2005
    NH is the granite state
    New Hampshire is known as the Granite State.
    Sep 2007
    Quote Originally Posted by hotgrips View Post
    I've always wondered why since Vermont seems to be better known for its granite these days.
    Regarding the use of granite as a base...it's a fantastic idea, not only for CNC, but for all sorts of other things. I think I'm going to try using a remnant as a base for my next jig.
    Registered neilw20's Avatar
    Jun 2007
    Thumbs up Air Bearings
    Using granite for slideways.
    Look here.
    http://www.newwayairbearings.com/Art...ID=52&CatgCnt=
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    1. Free CNC Drilling Machine Plans
      By yarko in forum Hobby Discussion
      Last Post: 10-04-2009, 11:11 AM
    2. Free CNC Machine
      By juzwuz in forum CNCzone Club House
      Last Post: 10-24-2006, 11:50 PM
    3. Free machine on craigslist - Boston MA
      By gto7419 in forum General Metal Working Machines
      Last Post: 04-15-2006, 06:38 PM
    4. Machine Design Magazine - Online Free
      By samualt in forum CNCzone Club House
      Last Post: 11-15-2004, 01:51 AM
    5. 18 Page Machine Design Free
      By vacpress in forum DIY CNC Router Table Machines
      Last Post: 04-19-2004, 03:03 AM
