Mass software?
Does anyone know of a program that will import cad drawing and spit out the mass and volume of the part? I don't need anytime to fancey.
Brian
Hi brian,
Are you talking about a 2D or 3D CAD file??? Format??
2d / 3d
Surface area can be determined in 2d but 3d is needed for volume / mass.
So won't the original application in which the 3D CAD file was generated give you the numbers you want?
ACAD, Solid Works, Inventor. pro-Eng etc etc will all give you mass properties. What is the file format?
Thanks I did not know SolidWorks had that option.
For the mass properties to be accurate, don't forget to set the materials properties to the material you want.
Hi every one.. thanks for your useful posts .. put i need a separat program doing this calculations .. if it available
thanks;
http://www.topshareware.com/AVD-Volu...load-12213.htm
this might be something worth looking at, not sure if it will import a file though.
Matt
Hello Dear Friends,
Is there any visual basic 6.0 source code that converts DXF or DWG file into G-code? I want to add this code in my final year project.
