well, what i would do is make a model of the 2 parts in Pro/Engineer. or something like that. Take the model to a local machine shop and see if they can run some of these off for you. If you dont have a model to start with, you cant do anything, even if you wanted to machine it yourself, so thats your first step.
The best way to produce anything depends on alot of variables such as product cost, tolerances, materials, and quantity. I cant tell for sure, but to me it looks like the manufacturer of the product you showed pictures of is doing a type of forging with a machining process after that for the holes. This process takes some extremely expensive equipment, but is great for large scale production. If you are looking to just make a few, i agree with the previous thread, make a cad model and bring it to a local shop for a quote. Typical shop rates range from $50/hr - $80/hr, so be ready to dish out some cash for small run prototypes. Some additional information would help us give you some more detailed help. Good Luck!
