Results 1 to 1 of 1
Thread: Sino-nsh Gas Engine Oil Recovery Secondary
    Aug 2006
    China
    Application
    NSH GER Gas engine oil recycling System is particularly suitable to recycle internal-combustion engine oil including diesel engine oil, gasoline engine oil and internal-combustion engine oils. GER series can effectively remove colloid, oxid, acid, pitch, particles, impurities, water, gas in the oil. Specially, GER can restore the color of used internal-combustion engine oil and remove the scent rapidly.
    Advantages of GER
    Design according to different needs of customers.
    Purify blend oils.
    Low operation cost.
    Low maintenance and replacement expenses.
    High regeneration rate.
    Automatic reverse wash system will extend the lifetime of filters and improve the performance of the filters.
    High performance security system including pressure protection device and automatic temperature controller makes purifier operate safely.
    Small size, light weight, low noise.
    Product Catalogue
    Insulation Oil Series
    VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
    VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
    VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
    VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
    GER Gas Engine Oil Regeneration System
    Turbine Oil series
    TF Turbine Oil Purifier
    TF-A Turbine Oil Automation Purifier
    TF-R Turbine Oil Regeneration Purifier
    Lubrication Oil series
    LV Lubrication Oil Purifier
    LV-A Lubrication Oil Automation Purifier
    LV-R Lubrication Oil Regeneration Purifier
    Flame-resistant Oil series
    FV Flame-resistant Oil Purifier
    FV-A Flame-resistant Oil Automation Purifier
    Explosion-proof series
    EV Explosion-proof Vacuum Purifier
    EV-A Explosion-proof Vacuum Purifier
    EP Explosion-proof Precision Filtering Purifier
    EP-A Explosion-proof Precision Filtering Purifier
    sinonsh22@163.com
    http://oilpurifier.ec51.com
    Attached Thumbnails Attached Thumbnails Sino-nsh Gas Engine Oil Recovery Secondary-ger.jpg
