Results 1 to 4 of 4
Thread: Newbie question - need help desperately
    Sep 2006
    Ireland
    Hi guys,
    This may be in the wrong place - admin please relocate as you see fit.
    I'll fill you in on the history of this problem first. I'm a 3d modelling engineer who creates concepts for architects. I specialize in 3D studio max 8 but I also know some Rhinoceros. Why all this blurb? Well I was given a task to create a 3D model to be cut from a piece of high density structural foam. This is to be done in a CNC milling machine in Australia. Having worked on the models appearance and structure and nearing the end of my time allowance - I found out that CNC milling machines require .stl files made from NURBS models and that polygonal objects cant work. This poses a big problem. I dont have time to remodel in NURBS and I have to have this thing finished in about a week.
    Does anyone know how a polygonal model can be converted into a NURBS model suitable for a CNC milling machine?
    Thanks in advance guys.
    Mar 2003
    Shelby Twp, MI....USA
    an .stl file IS a polygon model. .stl's are just made up of triangle polygons, like a .3ds file. You should be able to go from MAX to Rhino and export the .stl from Rhino. No need to use nurbs.
    Sep 2006
    Ireland
    Thanks!
    Thanks very much. I get the feeling Im being fed disinformation by a company that doesnt want or have time for this project.
    I really appreciate the reply.
    Sep 2006
    How big is it. Maybe you should consider using a different CNC vendor. Like ME.
    Dave Schell, SeaSchell Tackle Machining/Mfg./Design daschell2@cox.net 619 562-1835
