Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-08-2006, 02:16 PM
compositepro is on a distinguished road
cnc spindle drive(how to) question
hi guys
ive just finished machining up a spindle cartridge after being advised to make my own, someone showed me a picture of a simple one they had made
mines more of a cartridge with gamet precision bearings in either end and its oil cooled with r8 spindle tooling
now im stuck in that the theory was to buy a vfd and a 2hp motor and geardrive the thing using the vfd for stop , start and reverse
how ever researching into this has led me to the fact that belt drive from the motor to spindle are supposedly smoother and quieter
my intention was to use direct gear to gear ie motor gear to spindle but now im thinking more belt to a first pinion gear then direct to spindle
im troubled by how and if this could work being that reversing th motor woullead to some delay in spindle response and the associated forces which would be put through the belt
does anyoneknow or arethe vibrations so small direct drive that it doesnt matter how do they do this on industrial machines
regards
mike
thank smike
Old 09-08-2006, 02:41 PM
rfdoyle is on a distinguished road
Many (if not all) industrial CNC mills use a timing belt to drive the spindle. Even machines that rigid tap. With correct sizing of timing belt I wouldn't think you should worry about it. It you need to gear up/down, I would try to do it with the timing pulleys.
My $.02
rfdoyle
Old 09-08-2006, 03:12 PM
compositepro. I do not know what you are going to be cutting but in general I would reccomend timing belt / sprockets. No lubrication problems; when installed properly, no stretching on modern timing belts; Goodyears Eagle belts with herringbone teeth do not even require flanges; and they are quiet. A bit of warning though, be sure the spindle bearings can handle the radial load of the belt tension.
DZASTR
Old 09-09-2006, 12:23 PM
thanks guys precisely what i needed
