Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-03-2006, 10:04 AM
Gold Member
Rhodan is on a distinguished road
Recommendations for milling thick aluminium
What would people recommend as a minimum for milling out 1/2" thick aluminium parts? Stepper power, leadscrew size/pitch, and router power?
I'm looking at getting some 1/2-10 leadscrews and I can get between 127oz/inch and 500 oz/inch motors. Several of the routers that people have recommended are available locally as well. I just don't want to get 500oz/inch motors with a 1/2-10 leadscrew only to discover that the motors are too powerful and the leadscrew too wimpy!
P.S. the leadscrews are ACME with delrin nuts, though I do also have a 20mm ballscrew with 5mm pitch (slightly over 0.001" movement per full step w/1.8deg motors)
Old 09-03-2006, 11:50 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
for the most part it depends upon rigidity of your system , spindle torque etc 1/2 lead screws are wimpy , i would suggest 3/4-6 acme , less flex and less tpi
Old 09-03-2006, 01:10 PM
Gold Member
I should add that the cutting area will be quite small - about 22" by 12".
Old 09-03-2006, 01:17 PM
dertsap's Avatar
Gold Member
i live on the beleaf that anything can be cut on most anything , it s all how you approach it
Old 09-03-2006, 06:00 PM
Gold Member
Lol. ok, I'll try for thicker leadscrews.
Say, I see you're a Canuck too - have you found any online CNC sources (steppers, bearings, etc) here in Canuckleland? I've been googling but can't seem to find anthing
Old 09-03-2006, 08:12 PM
mxpro32 is on a distinguished road
with your small travels, 1/2" leadscrews should be fine. it's over the long lengths that they become wimpy.
Old 09-03-2006, 09:14 PM
dertsap's Avatar
Gold Member
steppers power ebay ,
leadscrews fastenal
misc my favourite Princess auto
