Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 08-30-2006, 05:10 PM
ad_bfl is on a distinguished road
Heat treating A36 MIG welded frame
General question.
I have built my lower axis/frame out of A36 1/4 wall tubing, welded using a MIG. The rails will be mounted to this after I have the ways surfaced by a blanchard grinder.
The Blanchard will only be removing less than .05 inches of material across the ways which are supported by the frame which is VERY strong.
When I built it in this manner I was planning on having it stress relieved before grinding, but a friend of mine who is a mech eng type says that given the strength of the frame and the small amount being removed, the stress relief process is wasted money.
Any thoughts on this?
Al
Old 08-30-2006, 06:21 PM
ad_bfl, we only deal with high precision metal cutting equipment so I don't know how it applies to your machine. We stress relieve & normalize after welding; then complete all but critical machining; final stress relieve then finish machine (bearing bores, ways etc.) grind slide surfaces and other critical areas. This equipment easily holds .0001" tolerances and can be quite expensive. Good luck
DZASTR
Old 09-05-2006, 03:07 PM
SeaSchell is on a distinguished road
If you don't stress relieve especially after welding it will "creep" over time. Maybe not much but who wants to chase things down later.
Dave Schell, SeaSchell Tackle Machining/Mfg./Design daschell2@cox.net 619 562-1835
