| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
I am looking for a device that can transfer electric signals in a 360 degree rotation. 4 conductors. You commonly see it in the dollar-store for the phone adapters that stop a telephone cord from becomming spiral/corded onto itself - because it has disks inside with springs mounted to it to allow electrical flow while allowing rotation. I need 4 conductors. Trying to build a small toy (it spins around, with lights that are controlled digitally - somewhat like a pan/tilt operation on a video- camera). The piece should cost just a few bucks. Unfortunately, I cant seem to find anyplace that sells these - the ones I have found want to sell me something for hundreds of dollars that is some type of professional robotic grade. If I managed to describe this well, I was wondering if anyone could advise or send me some links to try and check around, please thanks.
__________________ WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets. |
| Use a soft 4lead cable and turn it 4-5 turns like a spring and you should have 360degrees, however if it turns continous in one direction it wont work for obvious reasons. this is how the cablepack for fifth and sixth axis on most ABB robots are set up and so far I have yet to replace one. |
| Yes I thought about it and it gets more complicated involving my time. I went to radio shack and found a 4-wire telephone "detangler" device. I believe it will do the job; however - looks kinda cheap and flimsy. As long as I can push 5-12volts thru this I'll be in good shape.
| You can make it on a lathe from plain pcb. Turn 4 rings (or etch it if you like) on it. Make for the other side a pcb on which you can solder 4 phosphorbronze sliders at 90 degrees interval, they will be somewhere hanging around in a modeltrainshop as spare parts. Make an axle on one side, a bearing on the other side and you're almost there. Then give it to the kids and see how fast they brake it. |
| Well fkaCarol - that is definately some interesting information! Good idea to use that stuff for the transfer. I kinda figured about creating copper pcb rings, but never thought to poke around at model train shop for the bronze springs or bushings. There is a few hobby stores around the way I will check them out; I'm sure the guy at the counter I could pick his brain too probably.
#10
#12
