Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-20-2006, 12:44 PM
slp_prlzys's Avatar
slp_prlzys is on a distinguished road
rectangular tube 1/16th wall...tap or thru
I'm wondering if any1 could tell me if
it would be strong enough for a tube with
1/16 wall to be tapped. It will be holding
a thk rail with a dozen CBored hole.
I got me a table, with 1" melamine( I plan on adding 3/4 MDF on top of it),
but the frame is 1-3/4 and 1/16 wall, it seems perfect, for my application.
I just need to put a lot of braces .
Should I just use longer bolt then nuts,
the rail is not tapped, but needs M4 to get thru.
I've started my build with a footprint of 30"x30".
it will be used as an plexiglass cutter/engraver,
but will try to push it harder maybe cut 1/8 thick aluminum.(just maybe).
thanks.
Mhel
"me and my unselfish genes"
Old 06-20-2006, 02:02 PM
Gold Member
Ken_Shea is on a distinguished road
M4 is small, what THK size is that?. With a M4 and even a fine .5 pitch would account for only about 3 threads, not enough at all. If you have access to the inside you could insert say a 6mm backup strip and then tap that.
Ken
Old 06-20-2006, 03:20 PM
diarmaid's Avatar
*Registered*
diarmaid is on a distinguished road
1/16 wall what....aluminium...steel...?
Old 06-20-2006, 04:40 PM
ViperTX is on a distinguished road
either use an insert or a long bolt with a nut.
Old 06-20-2006, 05:17 PM
slp_prlzys's Avatar
the rails 15mm HSR model I think, unfortunately there's no
access to the inside of the tube, The frame is made of steel
and it's probably softer than usual.
I have the frame drilled and tapped, I'm trying to rig up a
power supply for my el-cheapo usb camera so I could show you
what it looks like ,but could'nt find the darn driver for it.
what I'm thinking, maybe I should just drill all the way to the other side
of the tube and use a longer bolt with 4mm or 5mm DIA ( what's the closest
equivalent of this in inches?) I guess this is my only option, or trash it altogether
and start from scratch which would make my build time longer.
Mhel
Old 06-20-2006, 05:32 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Even with a long screw, the tube will colapse!
You didn't say if you were a welder, but if you drill a 3/8 hole through both walls, and weld a solid pin from both ends and grind smooth, then you can drill and tap all you need! This would give 100% more strength and regidity, which will help in the long run!
Hope this helps!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 06-20-2006, 05:55 PM
diarmaid's Avatar
*Registered*
25mm = 1 inch.....therefore.....3mm = approx 1/8 inch....5mm = slightly less than 2/8 inch
Old 06-20-2006, 07:42 PM
slp_prlzys's Avatar
Here's a couple of pic I got just before I blew up a 7805 regulator.
I have it temporarily attached 4 screws holding each rails.
the X axis is surprisingly stiff. I think I'll sandwich the frame with 1/8"
flat bar, maybe it would work, I'm not sure what screw size I need
(preferably imperial) that has the right head size and has nut.
diarmaid:
thanks for the calculation, I'm hoping there's a imperial standard
screw that's almost the same size as M4, with head that would fit
on the CBOREd rail holes.
widgitmaster:
'am no welder but a friend who knows how to will be helping me
with the braces.
thanks.
ID:	19093   Click image for larger version
Mhel
Old 06-20-2006, 07:52 PM
Gold Member
8-32 or 8-36 will fit.
Old 06-20-2006, 07:59 PM
slp_prlzys's Avatar
I have another question while I'm at it ( so I dont' have to start another thread)
the aluminum on my x axis is 4.5" high is it wide enough to split
the two rails, I mean it would only be 3.5" apart if I put the two rails in it.
the plate for my Z axis is 6"x10.875", I'm hoping to have atleast 2-3" of travel for it.
thanks.
Mhel
Old 06-21-2006, 08:50 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Installing NutSerts in the tubing should work well for your application
www.integratedmechanical.ca
  #12   Ban this user!
Old 06-21-2006, 04:24 PM
slp_prlzys's Avatar
is this the kind of nutsert?
seems like a good idea.
I'll try the 8-32. with the nutsert 'wonder if it's available locally.
thanks.
Mhel
