Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-07-2006, 06:55 PM
Karl_T's Avatar
Karl_T is on a distinguished road
dinky servo
The attached pic is a view of an air motor to drive a lathe turret. The two screws, marked, are four inches apart. The section is three inches high.
The airmotor is just an armature with the steel cross-slide block seving as the housing. There is some room for metal removal here.
Is there any chance of finding a servo motor this small? What would be a good vendor? It only has to turn a turret and there's a huge gear reduction. I have no clue how to calculate the torque requirement.
Karl
Old 06-07-2006, 07:25 PM
Al_The_Man's Avatar
The break-away torque can be measured if you can attach a lever or some means of a attaching a spring scale and pull the scale until movement is apparent and note the scale value and then calculate the oz/in from the length of the arm, hopefully there is some practical way of attaching an arm etc?
Old 06-07-2006, 08:43 PM
Karl_T's Avatar
I could do that once I disassemble the whole unit. Big job. Right now I'm just trying to decide if I should rebuild a worn out air motor turret index unit or try a redesign. Is there a good selection of servos that will fit in a tight spot like this?
Karl
Old 06-07-2006, 08:59 PM
Al_The_Man's Avatar
I don't know the cost factor but for compact custom design the frameless motor is pretty compact. http://www.aerotech.com/products/motors/s.html
Down to 50mm.
Old 06-07-2006, 10:25 PM
unterhaus is on a distinguished road
this is the kind of motor that maxon or micro-mo would make. www.maxon.com or www.faulhaber.com
Both companies also supply gearboxes.
