Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-04-2006, 06:13 AM
wjfiles is on a distinguished road
command line control
Hi all,
Is it possible to operate a cnc lathe from the command line the same as drawing in autocad .So that the lathe would execute each step as it is entered.
I am thinking in terms of straight turning jobs rather that complex shapes.
Much like the old plug board machines if anyone is old enough to remember them.
Bfiles
Old 06-04-2006, 08:07 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Most CNC lathes have two ways to do this.
You can open the MDI (Machine Data Interface, I think), type in your command, and hit the run button to run that line.
If you have a program that you just want to run one line of, go to that line number, and hit the single step button.
Karl
Old 06-04-2006, 08:11 AM
Thanks Karl
