Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-19-2006, 10:19 PM
ZipSnipe is on a distinguished road
Mounting plates for milling head and Z axis?
As some of you might remember I,ve been building a manual milling machine and to mount my mini milling head to my column and z axis I had plan to use 1 inch thick plate in between the column and the z axis ( this is done so that there will be enough room to turn z axis handle)and 1 inch plate in between the mill head and the z axis. I had planned to use iron plates but ran into a problem when I went to 3 of my local suppliers they all didn,t have any. So I have a choice either I can do it out of 1 inch aluminum at about $20 cost or do it in 1 inch stainless at about $70 to $90 cost. I don,t mind spending the extra money for stainless if you guys think that would be better, but if you think I,ll be alright with aluminum I,ll go with that , either way I,d like to hear opinions on which would be better suited for mounting a milling head to the column? I,ll eventually use this mill to mill aluminum and some iron and some steel.
Old 05-19-2006, 11:04 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Call SpeedyMetals and get a quote on what you need, they have no minimum, and free cutting!
1-888-744-4140
I get all my stuff from them!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 05-19-2006, 11:57 PM
Thanx but which would you use to mount a mill head to a column? Aluminum or stainless?
Old 05-20-2006, 12:03 AM
Gold Member
for a milling machine, i would use steel or cast iron. For a router, i would use aluminum.
Old 05-20-2006, 01:19 AM
ViperTX is on a distinguished road
Aluminum plate or the cast aluminum plate (Mic6 or Jig Plate) will work beautifully.
