Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-04-2006, 04:14 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cool ACME - Can someone explain this?
I have been looking for sources for ACME, either Rods, Nuts, Taps, Dies, Gages, etc...
I have browsed through McMaster Carr for hours looking and compairing prices with other suppliers, but one common problem keeps slowing me down!
There is a void of ACME Taps, and GO/NOGO gages!
McMaster Carr sells more Acme stuff than any other supplier, they have the common 1/2-10 and 3/18-10 threaded rods, but only have taps for 1/2-10!
I realize that a lathe will cut a better thread than a tap, but some times a tap is more convienient!
Is there a premade carbide insert for turning internal ACME threads? I have been unable to locate them either!
Why is there such a void of ACME tooling?
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 05-04-2006, 04:25 PM
kdoney is on a distinguished road
Try http://www.e-taps.com/warehouse_3.htm they usually have some in stock.
Old 05-04-2006, 04:33 PM
Gold Member
Cool Thanks Kdoney!
Thanks, that is what I needed, they had a 3/8-10 ACME tap!
Eric
Old 05-04-2006, 07:19 PM
WhiteTiger is on a distinguished road
www.roton.com offers a good selection of pretty much everything acme. MSC has taps and also indexable inserts for cutting acmes as well as gages.
To be honest, I've never found mcmaster to be of much use at all, at least for the sorts of things I find myself shopping for. I've always found other suppliers to have more selection of better grade, cheaper.
Tiger
Old 05-05-2006, 02:56 PM
Gold Member
Cool
Amazing!
I ordered a 3/8-10 tap yesterday 5/4/06, and it was in my mailbox today 5/5/06!
Nice transaction, if only all were that quick to process orders!
Anyone know the drill size for a 3/8-10 acme tap?
Thanks again!
Eric
Old 05-05-2006, 07:27 PM
HayTay's Avatar
HayTay is on a distinguished road
Widgit,
Does this help???
Formula for Tap-Drill size for ACME taps
HayTay
HayTay
Don't be the one that stands in the way of your success!
