Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Lathe Turret Design
    May 2004
    Germany
    Lathe Turret Design
    I just want to show you this German guy's self-designed lathe turret:
    By a friendly request, the Designer (his name is Dieter),
    might send you the complete drawings by email free of charge. Please note: The Dimensions are metric !
    You will find his email address somewhere at http://www.cnc-projects.de/
    Regards,
    Fritz
    Registered DennisCNC's Avatar
    Aug 2005
    Clearwater, FL US
    Bablefish his site!!! Some nice machines he built!!!
    The auto toolchanger spindle is ..... killer!!
    Dennis
    Gold Member
    Apr 2003
    Ohio, USA
    Fritz,
    Did you get the cad files from Dieter?
    He graciously sent them to me but they are not the CAD files, rather .pdf for viewing only.
    His work looks more like art then mechanical.
    In my life I know only two people (Personally) that do such beautiful machining, I, unfortunately am not one of them
    Ken
    Banned
    Jun 2006
    Finland
    I have just began building mine, build log here: http://www.robosota.fi/foorumi/viewtopic.php?t=935
    Sorry it is in finnish but there are some pics to see
    Lots of thanks for Dieter, his design has saved incredible amount of designing!
    Mar 2007
    Romeo, Michigan, USA
    The direct link to the drawing file is:
    http://www.cnc-projects.de/CNC-Revolver.html
    [url]www.CNC-Joe.com[/url]
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Jul 2009
    i down loaded the design and find it vary well thought out great job to the designer! i was thinking of using this design in my lathe, but i don't want to use air to unlock the turret and i want to be able to cut towards tho tail stock. has anyone got ideas on what i should use to set up the tool changer in that way?
    thanks
    May 2006
    Denmark
    What do you want to unlock the turret with instead? Why cant you cut toward the tailstock? If loaded with powerfull enough springs, I doubt you will un-pop the head on such a smale scale turning if you cut towards the tail stock
    Jul 2009
    i was thinking of using fluid power since i have a lot of surplus hydrolic parts and my machine is 3 hp and is being built from steel plate so i will need to scale up the design. i like the design so the only thing i would change for my purposes is the unlocking mechanism and scale.
    i think you are right about the springs, but a heavy cut at 60 percent hp could in theory unlock the turret. i may be missing important factors in my reasoning but then i am always thinking of potentialities.
    however hooks law times four springs could apply a lot of force.
    the designer did an extremely good job and has made a nice contribution to my project because i will use his ideas. but i am new to CNC and still have a lot to learn so i was soliciting ideas, there is a lot of talent out there.
    thanks for your reply
    May 2006
    Denmark
    I use belleville washers instead of regular springs, take a look at the latest pics Slant bed CNC lathe from scratch
    My motor is also 3hp, but since i doubt I will do any serious production runs, if I ever cut against the tailstock I dont mind slowing down the feedrate. Have you calculated how much force it would take to unlock it with a given depth and feedrate?
    Jul 2009
    no, i haven't done calculations on this because i do not have any data on the springs used, also the Z component force the tool will generate (cutting tool apposition) to unlock the tourret i do not know how to calculate.
    horse power at the cutting tool is known and at motor, but what this translates to the tail stock and turret along Z axis is something i will need to find out.
    which is a good question, dose anyone know how to calculate component forces (using Full Body Diagram) an a lathe?
    Jan 2006
    I think you mean "free body diagram"
    Unfortunately, its a little more complex than just calculating a couple force vectors. The cutter geometry, material, speed and feed will all affect the amount of axial force.
    I am sure it could be figured out mathematically using the shear strength of the material, blah, blah, blah. If I wanted to find the force "good enough", I would put a torque wrench on the handle for the z axis and do a couple quick calculations (I think finding the pitch diameter on the drive gear would be all you need) to get a good idea of what forces I was seeing.
    Matt
    Jul 2008
    india
    Question
    Quote Originally Posted by Guldberg View Post
    hello guldberg,
    your turret design is awsome. but i was thinking about using 1 or 2 pins to lock the turret position while keeping the turret stationary (forward/backward)
    I want to use 2 angle contact bearings back to back on the tool plate that will give the turret a 0 tollerance and the pin will lock into the rotating turret.
    In short, in your turret design, the turret comes forward to the chuck, then moves and locks back to the tail stock. But in my design the locking pin will move only. So i don't need to worry about the spring tension and the power of pneumatic cylinder. Just an outcam or spring will move the locking pin.
    I hope you had this idea before cuz it is very simple. But what made you think that complicated. Any drawbacks of my design?
  • Page 1 of 2 12 LastLast
