Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 10-16-2003, 07:39 PM
bb99 is on a distinguished road
Question Duel Lead Screws
Hi All,
I'm in the process of designing my first CNC router table. The design that I'm thinking of will require a gantry span of 5'. I figure that my light-weight gantry design will not be stiff enough to be driven by just a lead screw on one side. I thought of placing a crossbeam underneath the table connecting the two legs of the gantry. However, I've decided not to go in that direction. Instead, I'd like to have a lead screw on each leg. Has anyone driven a single axis using two lead screws before? If so, how did you drive the screws (two motors)?
Thanks,
bb99
Old 10-16-2003, 07:57 PM
ljoe1969 is on a distinguished road
shopbot uses 2 motors on the x - axis. and rack and pinion istead of lead screws.
a friend of mine has one.
Old 10-16-2003, 08:40 PM
balsaman's Avatar
balsaman is on a distinguished road
You could go with two screws, one motor, two pulleys and a belt.
Eric
I wish it wouldn't crash.
Old 10-16-2003, 10:59 PM
CAMmando's Avatar
CAMmando is on a distinguished road
following up with Balsaman, check this thread
http://www.cnczone.com/showthread.php?threadid=1355
CAM
Wee aim to please ... You aim to ... PLEASE.
Old 10-17-2003, 11:30 AM
Greate ideas! This will give me lots to think about.
--bb99
There are 10 types of people in this world; those that understand binary and those that don't.
Old 03-16-2005, 03:38 PM
solarchimesam is on a distinguished road
BB99,
I run a twin steppers on X with one controller, its a low cost K179 driver.
screws on left and right side and works real good. You have to get the
steppers wired right. I could email you the wiring.
As a matter of fact if I turn stepper 1 by hand with power off, it will make stepper 2
turn...acts a brushless DC motor. With power on they are in perfect sync and push my heavy router and carriage with no troubles. I just increased the volts to the stepper controller + wire to make up for the extra current draw.
Best of luck!
Old 03-18-2005, 03:51 PM
bobleecnc is on a distinguished road
high this link doesn't work anymore can someone post the correct one? thanks.... Bob
how do i choose the right lead screws? dansal DIY-CNC Router Table Machines 32 04-06-2009 04:48 AM
Question obout acme threaded rod (lead screws) Hack Mechanical Calculations/Engineering Design 1 04-02-2005 01:12 PM
Twin lead Screws Joe_CNC Employment Opportunity 3 04-09-2004 01:18 PM
Lead Screws mdframe DIY-CNC Router Table Machines 14 03-21-2004 09:20 PM
Where to purchase lead screws? sixpence DIY-CNC Router Table Machines 2 01-25-2004 02:18 PM
