Did you see this previous post? rack and pinion backlash
You may be able to adapt one of these Rosta products as I did, the one I used has the torsion element built in at the pivot point, so there is very little to none in the way of external tension components. They are part of the line of motor mount/belt tensioners.
LinkBack URL
About LinkBacks
