Results 1 to 8 of 8
Thread: router table
    Gold Member
    Sep 2005
    united states
    router table
    Hi, I need help on deciding what motors i need for my router table. I have thk rails for all 3 axis , I am going to use rack and pinion setup 12p 12t spur on the x and y I have a ballscrew for the z axis 5 tpi 4" of travel.
    My table will cut 24x60" and use up to 3hp router for cutting hardwoods and plywood. My gantry will weigh approx. 50 pounds. I will be using geckos 202s and mach3. I was told that mach3 needs 1600 pulses per inch min. so I am assuming I need a 24:1 gear reduction because the spur gear at 1 revolution is 3" approx. on the rack.
    I dont know what I need here. How would I figure out what I need for this setup.
    Thank you Scott
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by planescott
    Mach3 doesn't "need" anything. Mach3 can output 45,000 steps per second max. With a G202, you'll need 2000 steps per motor rev. You'll probably want to choose a target speed and gear accordingly without exceding Mach's limit, while still maintaining adequate resolution. Motor torque can also be a factor, especially athigher rpm's.
    Gold Member
    Sep 2005
    united states
    1/10 micro stepping is 2000 per rev , if i am right i need 3:1 reduction.
    am i getting closer?
    Gold Member
    Sep 2005
    united states
    ok I am assuming that 300rpm on my steppers is a good top speed. If I use a 2.2:1 reduction at 300rpm is 7.13 in per sec , so then that is 14,272 pulses for mach3 a second and well within the range I guess.
    Does this make any sense Please help!
    Gold Member
    Sep 2005
    united states
    ok nevermind the last reply.
    I am know figuring 1000 rpm top speed for my steppers x & y axis
    I am using a rack and pinion 12t 12p which is 3.14" per revolution. so I
    think I need at least a 6:1 gear ratio which would be 523 ipm at 1000rpm
    and 8.72" ips mach3 would be putting out 33,333 pulses per sec.
    Does this sound like a reasonable setup.
    Thanks Scott
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    more speed = less power (torque) and its a heavy router I bet - plus the gantry. Sounds like it will be quite a machine though. Looking forward to pictures as it gets built!
    Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Aug 2004
    I would not use a ballscrew on the z-axis unless you already have a way to keep the ballnut from turning after loss of power....
    Gold Member
    Sep 2005
    united states
    I guess I will have to play with the gear ratios a little bit. I should have some pictures by next week I will put them on here.
    How would I stop the ballscrew from dropping if I lost power?
  • Posting Permissions
