Nice...any reason why you didn't directly drive each axis ?
foto's off the cnc I building now this is the frist
I will just this for models in waxs .Because I a goldsmit
Nice unit!
I like the T-slot table top, you did it with the simplest of components too!
Very creative!
Eric
I like it. Especially the first picture with the senseo in the background.
(my cnc-machine and my senseo are the two most valuable machines to me)
I see that you used drawerslides, what kind of accuracy do you get with them.
Very nice job.
Jeroen
____________________________________
Jeroen
Not directly on axis , because I want a little more
power a go for motorgear 16 t an axis 22 t
I just drawerslides prices is low.(because 1e cnc) nex machine I want to just better
Help , I want the test my steppenmotor's with out the drivers .witch's color off wire I must connect
I want to just my old computor for it.(12 volt)
steppenmotors are 2 Phase Hybride
Dielectric strength:500VDC
Insulatie resistance:100MOhm(500VDC)
Torgue(Nm) 1,3
current/coll (A) 1,4 -- Voltage/Coll (V) 1,96
color wire Bleu-Red-Yellow-Green-Brown-Black-Orange-White
I can not go to the shop now is close an I want to tray now
Thank you for now , regards fred
For testing you can probably use the 5v of the computersupply (less heat).
I don't know the brand of your steppers and I don't know if there's a "world-wide" standard in steppper wire colors (there should be).
But the attached files helped me in connecting my steppers.
Succes,
Jeroen
Jeroen
Fred,
You have done a fine job! Can you tell us which motor controller and software you will be using? Keep us informed.
Evodyne
I just the set from www.stappenmotor.nl the set is number 4.3 a
There you see everthing over the set.
Software I want to just TurdoCNC V 4.01 because I just a
old dos computor.
