Results 1 to 5 of 5
Thread: Constant Drilling Force
    Aug 2011
    canada
    Has anyone setup a automated drilling machine that applies constant force during a drill operation.
    I'm setting up a machine to do this and i'm contemplating setting up the drill feed axis on an air actuator to ensure the bit experiences constant force.
    Feb 2009
    Air does not work well. Since the tool will change loads, entering and exiting, you will get a build up of air pressure in the CYl that will release once the drill starts breaking through. This will jam the bit through once the tip penetrates the part. You need something less compressible. Think hydraulic, or air over oil.
    Honestly, now days, it may be cheaper to use a stepper motor with something like arduino to control it.
    Aug 2011
    canada
    i am familiar with the arduino boards as i currently use them to control transportation robots.
    How would you control the constant torque on the stepper. from my limited knowledge i thought steppers required step and direction instrustions and you vary the speed by changing the step pulse. Is the torque related to the input voltage on the stepper?
    Feb 2009
    I believe it would be input current. Voltage would give you speed. I'm a servo guy, not much with steppers.
    Jan 2006
    Why does the force matter? A stepper wil give you a constant feed which will be pretty close to a constant force.
    Matt
    1. Constant Force Springs
      By rrobb in forum Benchtop Machines
      Last Post: 09-06-2011, 03:23 PM
    2. Need Help!- Spot Drilling/Center Drilling Steel 55 HRC
      By JWB_Machining in forum General Metalwork Discussion
      Last Post: 03-11-2009, 02:35 PM
    3. Constant Force Spring for Counter Balance
      By biomed_eng in forum DIY CNC Router Table Machines
      Last Post: 10-25-2006, 10:10 AM
    4. PWM Vs constant current
      By JerryFlyGuy in forum General Electronics Discussion
      Last Post: 10-25-2005, 05:48 PM
    5. How to make a Constant Force Spring
      By jwvica01 in forum Benchtop Machines
      Last Post: 06-27-2005, 08:17 PM
