What diameter of bore do you need. Any preference for GT2, L, H , L, XL, MXL or pitch?
Bore is for 1/2" shafts.
Don't know what size is best or what pitch is best. All I know is that I think that 1/2 wide belt will be too small and that I might have to use a 3/4 wide belt.
Peter
Peter
Off track to your question I know but have you tried http://www.smallparts.com.au They are in Mansfield, Qld.
Andy
For the GT2 5mm pitch pulleys with 1/2 inch bore, 15mm belt width (0.691 inches), the best ratio is about 3 to 1. What would you like to do?
andy_ck87028,
smallparts.com.au actually use the sdp-si.com stuff. My email ended up getting directed to smallparts.com.au
I still like the idea of going with sdp-si.com as the shipping is direct and it is also faster to get here.
ViperTX,
I like what you have sugested. I have had a problem with the whole plasma table vibrating like its convulsing after having a hard night on the grog.
So I decided to see what would happen to the noise/vibration if I was to disconnect the motor away from the pinion. And what I found out was that the really loud noise disapeared.
So the vibration must be transfering to the rack from the motor. Now I am thinking that by using a rubber timing belt this vibration will not be transfered to the rack???
I like the idea of the stuff that you reccomended ViperTX. I will now try to find all the part numbers to order the stuff that you reccomended.
Peter.
