Results 1 to 3 of 3
Thread: calculating load required to move oz/in
    Dec 2011
    My goal is to figure out what motor strength I need for my fixed gantry moving bed design 36"x40" system.
    I've followed the formulas on the Geckodrive page to calculate PRS and PPS, but when it comes time to plug in the load required (oz/in) to determine motor strength I'm stumped. Where do they pull out the 450 number? How can I calculate my own load required to plug into the formula?
    Jul 2011
    Looking at: Support
    The 450 oz/in is an arbitrary number they chose for the example. They are notating the unit wrong though. It should read 450 oz-in. No division in torque units.
    I have no idea what kind of system you're dealing with nor do I know anything about CNC machines for that matter but perhaps you could use a torque wrench to get your figure roughly. There are other ways by they're far more involved.
    Dec 2003
    Try one of the free sizing programs such as Kollmorgen.
    One main deciding factor in motor sizing is required accel/decel (inertia).
    Static or break-away torque is only a start.
  1. Problem- OI-TB move part program load to pendant
    By BAFJB in forum Fanuc
    Last Post: 02-02-2010, 04:35 PM
  2. Help calculating load on a nut
    By Brenck in forum Mechanical Calculations/Engineering Design
    Last Post: 05-04-2009, 11:29 AM
  3. calculating expected max cutting force required
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-01-2007, 07:19 PM
  4. calculating a rough estimate for bearing dynamic/static load
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-20-2007, 11:20 PM
  5. Calculating series load resistors
    By whateg01 in forum Stepper Motors and Drives
    Last Post: 12-03-2005, 11:28 AM
