Results 1 to 4 of 4
Thread: Aluminum fan for motor
    Sep 2009
    Customer had a motor that had a fan come apart. Machining new ones for them out of 4" thick 7050 aluminum 19" diameter. Using a 3/4" ball endmill to machine so there is a good radius in the corner where the blade meets the hub. This a good type of aluminum to make these fans?
    Attached Thumbnails Attached Thumbnails Aluminum fan for motor-2012-02-27_16-55-59_80.jpg   Aluminum fan for motor-2012-02-27_16-37-16_635.jpg   Aluminum fan for motor-2012-02-27_16-35-19_929.jpg
    May 2004
    That does not look like a typical fan by any means. How fast was it turning? 10,000 RPM?
    Nothing wrong with 7000 series aluminum that I know of.
    http://www.kirkcon.com/
    Sep 2009
    Fan
    The fan goes on a 200 HP motor runningat 1800 rpm.
    Feb 2009
    Nice. Should hold up fine at that rpm.
  1. 80/20 aluminum gantry, milled aluminum ends
    By 3Dsigns in forum DIY CNC Router Table Machines
    Last Post: 10-15-2010, 04:55 PM
  2. Securing Aluminum to Aluminum
    By webgeek in forum General Metalwork Discussion
    Last Post: 12-29-2009, 06:30 AM
  3. Bonding aluminum to aluminum - Doable? How?
    By Arquibaldo in forum General Metalwork Discussion
    Last Post: 11-05-2009, 10:01 PM
  4. Carbide endmills Aluminum vs non-aluminum ???
    By zaebis in forum General Metalwork Discussion
    Last Post: 09-14-2009, 09:53 AM
  5. pressing aluminum into an aluminum tube
    By Fishin_Rod in forum Mechanical Calculations/Engineering Design
    Last Post: 07-01-2009, 01:23 AM
