Results 1 to 2 of 2
Thread: Spacial machining ..piston connecting rod
    Jan 2011
    india
    hi guyz..
    i have good knowledge of making diy cnc machines ... i made a cnc router for experiments... and i want to start a new project now...
    i have a very big job work of machining the 2 ID holes on each end of a connecting rod of a piston to crank shaft...
    i want to automate it... so my question is which type of machine will be more helpful ? a cnc milling machine or a cnc lathe ? which one will be more practical ? currently this job is being done on a manual center grinding machine...
    Mar 2006
    More information (con-rod dimensions and tolerances) is needed to give you an intelligent response to your question.
    Dick Z
    DZASTR
  1. Problem- Air Piston..how does it work?
    By turbo2ltr in forum General Metal Working Machines
    Last Post: 01-29-2010, 05:46 PM
  2. Help with IC engine piston manufacturing
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-18-2009, 12:45 AM
  3. Piston casting,
    By Honda_Dirtrider in forum I.C. Engines
    Last Post: 05-03-2007, 07:02 PM
  4. Help with simple piston Design
    By inmemarcos in forum Mechanical Calculations/Engineering Design
    Last Post: 02-14-2006, 04:03 PM
  5. Replies: 1
    Last Post: 12-28-2003, 08:06 PM
