Results 1 to 10 of 10
Thread: Will a 13mm bearing fit on a 1/2" pipe?
    Dec 2011
    united states
    im ordering linear bearings so the size given is the size of the hole im assuming. the bearing size is 13mm which = .51" so technically it should fit the pipe and off by a hundreth. But i wanted to make sure and run it by you guys before i puchased bearings.
    Mar 2003
    Shelby Twp, MI....USA
    A13mm linear bearing will not work on a 1/2" shaft.
    Dec 2011
    united states
    Quote Originally Posted by ger21 View Post
    ty for your response. what is the reason? to big or to small or what size could work?
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    1/2" pipe has an od of .840 inches and even if it was the right "nominal" od, the finish would NOT be good enough for this application.
    Art
    Mar 2003
    You need to use hardened 13mm shafts. That's the only thing 13mm linear bearings will work on.
    Dec 2011
    united states
    okay thanks for the responses, i guess ill have to spend some more on the right hardware...and i think 13mm hardened shaft might be to thin/weak for my size machine also (30"x30"x20") correct?
    Apr 2009
    Quote Originally Posted by Ncrazyballa View Post
    13mm is an odd diameter, I'd recommend sticking with something more standard. I see Thomson sizes as 10,12,16,20mm... for metric. Or go with inch size, 3/4" maybe.
    Size wise, it depends what your loads are and how they are supported. Are you supporting them only on both ends? Check the deflection over 30". Or will they be full supported throughout the length?
    As ger mentioned you need to use hardened shafting with linear bushings for them to work properly.
    Sep 2006
    Hi Ncrazyballa, perhaps if'n supplied a sketch of your proposed machine design you would get a more detailed response as to what you can and can't do.
    Just by reading your request re the linear bearing/pipe set-up indicates you are totally unknowledgeable of engineering requirements for materials etc.
    Ian.
    Apr 2009
    Quote Originally Posted by handlewanker View Post
    Hi Grego85, perhaps if'n supplied a sketch of your proposed machine design you would get a more detailed response as to what you can and can't do.
    Ian.
    I'm confused, I merely offered some suggestions to the OP above regarding shafting.
    I'm not the one building a machine, I believe your intention was to address NCrazyBalla?
    Sep 2006
    Hi, apologies, misread the heading.....duly corrected.
    Ian.
    1. 16" Pipe Headstock
      By nomangadiwala in forum Mechanical Calculations/Engineering Design
      Last Post: 09-11-2011, 03:53 AM
    2. Build Thread- need help with 2.375" w/ 11.5 tpi on a pipe
      By buffaloguy in forum General Metalwork Discussion
      Last Post: 04-30-2011, 09:35 PM
    3. Chinese Spindle, "Germany" bearing mystery solved!
      By Tim Nye in forum DIY CNC Router Table Machines
      Last Post: 10-19-2010, 02:18 PM
    4. Pipe Bearing Adjustments (JGRO)
      By bcromwell in forum JGRO Router Table Design
      Last Post: 06-20-2005, 05:16 PM
    5. gas pipe & linear bearing dimensions relationship
      By zoltan in forum Linear and Rotary Motion
      Last Post: 06-13-2005, 04:12 PM
