Dp you need accuracy better than 0.01mm? I would think you would want your smaller reamer for the holes in the fixture, so the dowels are pressed in permanently, and the next size up for the part sitting on the fixture so you would have a light press or light clearance fit so it would be reasonably easy to remove. Is the problem that you are not lifting the part straight so it is binding on the pins? If that is the case you could chamfer the holes or reduce the pin depth so you have less engagement which will reduce binding.
Matt
LinkBack URL
About LinkBacks
