If you size the hole correctly some thread forming screws might work...you'll have to experiment. The metal roofing screws are designed to thin guage metal and will probably snap in 1/8 inch thick steel. Nuts and bolts will also work. I probably would shy away from rivets and threaded inserts.
LinkBack URL
About LinkBacks
(Couldn't find the smile)
