Results 1 to 1 of 1
Thread: Radial Engine, Master Con Rod
    Dec 2005
    Hey guys, so I'm designing a 5 cylinder Radial, with a bore diameter of 1.1" and 1" stroke (might increase stroke length). I'm having trouble with the Master con rod. I'm unsure of where to put the 4 slave rod connecting points. It can't be the typical 72 degrees (360/5), since TDC and BDC isn't 72 Deg on the crank relative to the master con rod.
    I've taken some pics of the assembly, and drew an approximate motion path of the 3rd con rod connection point. It's sort of an ellipse, but not quite. I've tried making the master con rod longer and shorter, and moved the connection point around, but still doesn't make a circular path.
    Is this typical for this type of crank/ con rod arrangement on radial engines?
    Attached Thumbnails Attached Thumbnails Radial Engine, Master Con Rod-image1.jpg   Radial Engine, Master Con Rod-crank2.jpg
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  1. CNC Radial Engine
    By MMT in forum I.C. Engines
    Last Post: 04-27-2012, 12:56 PM
  2. NEW : Radial Bi Rotary Engine
    By frankydevaere in forum I.C. Engines
    Last Post: 03-11-2011, 01:41 AM
  3. cox radial engine project
    By tonycorse in forum I.C. Engines
    Last Post: 04-12-2010, 02:47 PM
  4. Cox radial engine
    By mrplentyolde in forum I.C. Engines
    Last Post: 04-09-2010, 11:03 PM
  5. radial engine Siemens Sh 14
    By esler in forum I.C. Engines
    Last Post: 02-12-2008, 07:31 PM
