Hi, When I made the pulleys I rounded off the teeth to much. The weight of the mag rotors is about 20 pounds and there is a lot of force being applied to the teeth on the pulleys to start the mag rotors spinning. I am using a wider belt and machining new pulleys to better match the profile of the teeth on the belts to solve the problems. Thank you for all the suggestions.
LinkBack URL
About LinkBacks
