Hi to all Dear industrial men
can you please help me for calculate feed rate and rapid travels of CNC machine?
i have a Servo motor with :
Rate speed : 2000 RPM
Max speed : 2800 RPM
I use ballScrew with 5 mm lead.
Does the maximum feed rate is : 10000 mm/min
Does the Maximum Rapid travels : 14000 MM/min
I read ballscrew catalog and the ratio of maximum speed and max rotation for select lead is :
15000 mm/min and 2800 rotation
Then we select 5 mm lead.
Can you please help me if i must consider any other ratio ?
Thank you
