Results 1 to 8 of 8
Thread: ball screw question
    Jun 2010
    ca
    ball screw question
    Hi to all
    Can some one help me and tell me: In the ballscrew with 25 mm diameter, which kind of bearing(fix or support bearing) and how bearing install in the end ballscrew shaft?
    Fix bearing ?
    Support bearing ?
    Can you please tell me about install of bearing in end shaft?
    Thank you
    May 2008
    Since there have been no replys I will give it a try. Looks like the left end of the shaft is setup for a pair of anglual contact bearings at locatin "C". It looks like a collar/spacer goes on next followed by a nut with an M20x1 thread. The nut is tightened on the spacer which clamps the bearing inner race to the setp on the lead screw. The right end looks like it's set up for a plain bearing as the journal is much shorter. It also has a spacer then a nut but I would bet the bearing if semi floating in the bearing block to allow for thermal expansion.
    This is exactly how my Bridgeport is setup.
    Craig
    Jun 2010
    ca
    So i must use Fix bearing in both side?
    Yes?
    Mar 2006
    The bearing on the right end is designed to "Float" or move within the end support housing. As Craig said, this allows the bearing to move axially if the ball screw grows due to thermal (heat) expansion while preventing radial motion (whip).
    Dick Z
    DZASTR
    May 2008
    Just to be clear, the angular contact bearing set on the left constrains all the axial load in both direcitons the right side bearing floats in the holder and just constrains the radial load of the ball screw.
    Craig
    Quote Originally Posted by sml2010 View Post
    Yes?
    Jun 2010
    ca
    hi to all
    Thank you for your answer.
    I understand that we must use float bearing on the right side but my question and my confuse is for instal float bearing in this location, because :
    this location have a thread in the right side like thread that is in the left side . I all bearing that have nut and spacer, Doesn't have movement throw the holder.
    And if i use float bearing, the float bearing doesn't have nut and spacer for fasten and locate the bearing in the shaft
    can you please tell show me a bearing with nut and spacer that can float throw the holder?
    sorry if i don't understand your teach and ask again
    Thank you
    Mar 2006
    The nut on the right end holds the bearing in place on the shaft. The outer race of that bearing is not held in place axially within the bearing support block. The support block has room that allows that bearing to move axially, it "floats" axially.
    Dick Z
    DZASTR
    Jun 2010
    ca
    Thank you for your kindness
    1. Ball screw question.
      By Nth in forum General Metal Working Machines
      Last Post: 08-25-2010, 02:48 PM
    2. Ball screw question from a new guy!
      By ben_kapitan in forum CNCzone Club House
      Last Post: 04-18-2009, 11:19 PM
    3. Ball screw Question
      By rodzilla in forum Linear and Rotary Motion
      Last Post: 03-02-2007, 05:16 PM
    4. acme screw to ball screw question
      By Billw in forum DIY CNC Router Table Machines
      Last Post: 07-18-2005, 01:10 AM
    5. Ball Screw Question
      By jjwl89 in forum DIY CNC Router Table Machines
      Last Post: 07-20-2004, 08:12 AM
