Results 1 to 3 of 3
Thread: NEMA 34 shaft diameter specification
    Oct 2007
    I recently ordered a NEMA 34 stepper motor and found the shaft diameter was 0.62" diameter. I was under the impression all NEMA 34 motors had a 0.50" diameter shaft.
    Just curious if the NEMA spec specifies shaft diameter, or is it just the frame mounting dimension?
    Dec 2003
    Is it maybe actually a IEC mount and a 16mm shaft?
    Oct 2007
    I suppose it could be....the mfg calls it a NEMA 34 motor though.
  1. Need Help!- How to grind shaft of 2.0 mm diameter
    By Ashish B in forum General Metal Working Machines
    Last Post: 01-02-2011, 02:06 PM
  2. Need Help!- Nema 34, 400 oz, 3/8" shaft
    By imaracingmom in forum Want To Buy...Need help!
    Last Post: 10-16-2009, 10:52 AM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 03:51 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum General Metal Working Machines
    Last Post: 12-14-2007, 10:25 PM
  5. 1/4 to 3/8 nema 23 shaft
    By dgalaxy in forum Stepper Motors and Drives
    Last Post: 12-16-2006, 01:28 AM
