Results 1 to 5 of 5
Thread: Deflection calculation - 20mm rod
    Jul 2011
    I would like to ask for some help calculating the deflection of 60" long unsupported rod of 20mm hardened steel. I have used the BeamBoy as well as the formulas from SKF Linear Material documentation, and my results are unrealistic.
    I am looking to see the deflection of a 20 lb force hanging from the dead middle of a 60" long piece of 20mm hardened steel clamped at both ends. My computations so far give me deflections way below 0.1mm - which would be great, but it would be too good to be true.
    I am a week-end woodworker and am not very handy with metal. I don't know what to expect. Tolerances of 0.5 mm are acceptable for me, maybe even 1mm. I don't want to go to 25mm or 30mm rods unless I have to.
    thanks for anyone who would venture to start helping a noob
    cheers,
    wm_crash, the friendly hooligan
    May 2009
    Sounds about right, 20 pounds isn't much.. Trust your equations
    http://www.advancepipeliner.com/Reso...n_Formulae.pdf
    May 2009
    Moment of inertia (I) = pi*r^4/4
    Modulus of Elasticity (E) for steel = 30,000,000PSI
    l = 30"
    P = 20lb
    I=3.14*.394in^4/4
    I= .0189
    Ymax=20lb*30in^3/48*30,000,000PSI*.0189
    Ymax=.0198 inches or .504mm
    BTW - this is for a simply supported beam, not a clamped one so the actual numbers will be less.
    Jul 2011
    I really appreciate your help! My situation is far better than that . . . I simplified things a little. I am going to use two rods and will have a router (less than 20 lbs) travel on a fixture with linear bearings.
    I am planning to build some drums and was looking for a solution to round the inside of rather long and narrow shells. I make the shells from staves, like a barrel. My plans are to have the shell rounded on the outside first. Then I place it on some bearings (well secured). I place the 2 rods through the shell and ride the router while I slowly turn the shell. With a router angled at 60 degrees, and using a 120 degree V-bit, I can (at least on paper) have a smooth finish on the inside.
    Thanks again for the help!
    cheers,
    May 2009
    No problem, nice little refresher for me
    1. Deflection
      By nofx in forum Mechanical Calculations/Engineering Design
      Last Post: 02-23-2010, 08:16 PM
    2. How much deflection is too much?
      By Dman65 in forum Mechanical Calculations/Engineering Design
      Last Post: 08-12-2009, 09:58 PM
    3. Need Help!- Deflection Calculation
      By Freff in forum DIY CNC Router Table Machines
      Last Post: 11-05-2008, 08:40 PM
    4. Shaft deflection
      By CNCTerry in forum Linear and Rotary Motion
      Last Post: 06-30-2007, 10:49 PM
    5. Deflection calculation software
      By bdrmachine in forum Bending, Forging,Extrusion...
      Last Post: 09-20-2005, 09:01 PM
