don't use a spring use a rigid setup.
Working on my plasma table again. Frame work done, X axis done via ballscrew.
Not sure how I want to do the other axis.
I have a rack/pinion mounted on both sides, with the teeth facing down (idea is so dirt doesn't fall into teeth).
On the gantry I have a driveline that runs to both sides, servo mounted on one side driving that shaft. Output of that shaft obvioulsy needs to transmit power to rack (well pinion). Driveline Shaft is about 5-6" above the rack.
At first I had a swing arm setup with a spring pulling up on it to force pinion on to the rack. It was rather sloopy and I just didn't like it.
Need some ideas, either spring loaded or not. Pictures are even better. I may try to get some pics myself tonight.
Ready to move forward on this but after a few days not sure how.
Found one picture close to how mine is setup, but since I have the driveline to prevent racking of gantry I can't mount motor directly onto rack as it is here.
but doesn't a rigid setup get tight and loose as it goes across the rack. Mine sure seems to.
Have you looked into anti-backlash pinion gears. The gear is spit and and has a preload to push the two pieces in opposite directions. Here is a link. http://www.wmberg.com/catalog/pdf/b00b117a.pdf and a picture.
so, is the looseness due to variation in the rack....its mounting...on in variation in the distance the pinion is from the rack....which is most likely due to the flatness/straightness of table guide assembly.
Hey ty1295,
That's my plasma machine. The spring setup works brilliant. I have to make sure that the acceleration is not set to fast in Mach3, otherwise it will jump gears and the rack. But other than that is is great.
Have you seen the video?
Peter
I also have a spring setup.. It works great for me and I dont' notice any backlash. One thing to keep in mind is its best to keep the pivot point of the motor mount/spring assembly in the same plane as where the rack and the pinoin mesh together. (there has to be a better way of explaining that..lol) By doing this it is much less likely for the pinion to jump a tooth on the rack.
Jeff T.
Rig an adjustable stop behind the arm that holds the pinion and adjust this so the pnion can move the distance needed to accommodate variation in the rack position but cannot move far enough to jump a tooth.Originally Posted by Apples
Geof,
That sounds like a good idea. Might have to do that. I am having problems at the moment with the gantry wobbling at one end(opposite to motor end).
Looks like I am going to have to buy another Gecko and motor. Hopefully this should fix it up really good.
That end probably moves about 4-5mm. ie. I do a fast jog at high speed then stop and the end of the gantry wobbles.
Peter
Here is how I did it, http://solsylva.com/cnc/4cnc54.html (scroll down) works well; once adjusted it has never jumped a tooth. Went with this system because I could not come up with an inexpensive swivel that would be backlash free. The adjustable gibs dealt with that problem easily enough.
The arrangement of the set-up also tended to the problem Jeff T mentioned in post #7.
Peter;
I looked at the picture someone posted that you say is yours. Your gantry wobble may be coming from flexing in the frame you have tieing the two sides of the gantry together. From the picture it is possible to see you did a very sturdy job of mounting your guide rails but it appears you used fairly light angle to tie across from one side to the other; lighter than your rail supports anyway. If it is possible see if you can weld on extra angle to turn them into square tubes; the stiffness will increase considerably.
My cnc is going to have hardened shafts at each side for the x axis with 2 pillow block bearings placed 12 inches apart on each shaft. The shafts are predrilled and mounted on shaft rails. There is only one motor on one side powering the x axis by use of a rack and pinion. The table is very very sturdy and heavy duty and stiff in all directions. I cant see any wobbling happening here from this setup. What do you think? (asking for your input).Originally Posted by Apples
