Results 1 to 5 of 5
Thread: Calculating Radius at End of Taper
    Jul 2010
    I have a piece of steel I was going to mill like this:
    I think I’d like to mill it like this, with a radius at the end of the tapers:
    ...which raises the question of how I calculate the radius.
    I found the following in Holbrook Horton’s “Mathematics at Work”, 4th ed., p. 13-2.:
    Horton solves for the diameter bc, given radius de and the angle of taper A as known.
    My question: I’m wondering if its possible to solve for the radius de given bc and the angle of taper A as known, or some other known values, such as the length from the beginning of the taper to b and c???? I want to be able to drop that radius value into a CNC G03 command.
    The formula Horton gives to solve for bc is:
    The derivation goes like this:
    Thanks for any help with this. I'm just starting to learn trig, and get a little lost around cotangents, but I can plug known dimensions into formulas.
    Jul 2003
    New Zealand
    This may be of some help.
    de = (bc/2) / tan((90-(A/2))/2)
    eg
    de = (20/2) / tan((90-(80/2))/2)
    de = 10 / tan((90-40)/2)
    de = 10 / tan(50/2)
    de = 10 / tan (25)
    de = 21.4451
    Attached Thumbnails Attached Thumbnails Calculating Radius at End of Taper-eliot_1.jpg
    Jul 2010
    Thanks a million for that. Exactly what I was looking for. Really appreciate it.
    I found your diagram super helpful. What did you create it with??? I'm a little limited in what I can work out with the software I have, and would love to get something inexpensive that would let me do exactly what you've done: draw angles and radii to scale.
    I can't afford anything fancy, just want to draw angles and radii to scale, literally. Can you think of anything???
    Jul 2003
    New Zealand
    Jul 2010
    Thanks. Downloading it now. Look forward to giving it a test drive when I get home from work.
    1. Replies: 0
      Last Post: 03-23-2011, 04:20 PM
    2. Need Help!- Radius to end of Arc Differs From Radius to Startline
      By Bob La Londe in forum Machines running Mach Software
      Last Post: 08-09-2010, 10:16 PM
    3. Calculating "zero" with Radius tool...
      By CyborgCNC in forum Mastercam
      Last Post: 01-06-2010, 10:29 PM
    4. Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread
      By bdyenter in forum General Metalwork Discussion
      Last Post: 09-16-2009, 09:10 AM
    5. Need Help!- Radius to end of arc differs from radius to start?
      By Jamy in forum LinuxCNC (formerly EMC2)
      Last Post: 08-23-2009, 12:28 AM
