Results 1 to 3 of 3
Thread: Formula to mill radius
    Jul 2007
    Question Formula to mill radius
    Is there a formula to set the head tilt in order to machine a radius in bar stock? Years ago I saw a shop that was cutting a radius in bar stock by tilting the milling machine head and using a large end mill. I need to do this in aluminum. Thank you. Ron
    Mar 2006
    Sol 3 (YVR)
    Although I make no claims for accuracy, cutter radius divided by the sine of the angle away from vertical appears to give an approximate answer. Note though that the cut surface will actually be a section of an ellipse, not a circle. With the head over at 90 degrees, sin(90) = 1 and obviously the resulting cut radius is the same as the cutter and with the head vertical, sin(0) = 0 and the cut radius is infinity - in other words, a straight line.
    Jul 2007
    Thank you. I will give that a try. Ron
  1. Need Help!- Radius to end of Arc Differs From Radius to Startline
    By Bob La Londe in forum Machines running Mach Software
    Last Post: 08-09-2010, 10:16 PM
  2. Replies: 8
    Last Post: 11-15-2009, 07:35 AM
  3. Need Help!- Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 12:28 AM
  4. Replies: 1
    Last Post: 01-23-2009, 02:37 PM
  5. Advice on setup / speed / feed for 1/2" Radius corner rounding end mill
    By peter.blais in forum General Metalwork Discussion
    Last Post: 05-23-2007, 04:16 AM
